Your going to need to look into led's. I know at pepboys they sell a tail light bulb but its not a bulb it has about 10 led's where the bulb goes. they are really bright and only red not pink like that fadeing crap. The only problem is when i bought them for my old cavi, they kept poping my fuse for the tail lights. So I bought a diff. brand and had no prblems.
I had that problem also but get extra bulb sockets(wallmart?), if you can find some then splice em in and tuck the bulbs under the carpet and run the LEDs in the tails?
just an idea
Sinfire (Formally SpyderWizard wrote:I had that problem also but get extra bulb sockets(wallmart?), if you can find some then splice em in and tuck the bulbs under the carpet and run the LEDs in the tails?
That works perfect.  I ordered LED's from
http://www.lumileds.com/ (luxeon emitters) and bought extra bulb sockets from Autozone.  Epoxied the LED's in the turn signal part (toyota cav tails) and just tucked the socket behind the carpet.  Haven't gotten a "hyper -blinker" since.
pep boys has red bulbs..i got em in my tails  i had the same problem
get an orange bulb and put a red gel cover over it it will be pure red (done it before with my sunbird, ive replaced the b/up lights with  this and converted them to blinkers)
They will.
Go with Lumiled's luxeon emitters. You can't go wrong with them. Hook a proper resister on there and they'll be perfect.
Interior FAQ -
J-Body of Michigan -
Or you could get what i had on my s10 for a little while
HERE
