ok I really think I should get some hood pins...what the best kind or brand? Also where the heck do these mount??? LOL I have a sunfire with the CF invader hood. help! thanks <br>
PROJECT EXTREME SF IN PROGRESS. HOPEFULLY DONE BY MARCH 05
i have the ones from pep boys, apc i believe.  they work fine.  if you open your hood there are 2 rubber stoppers on that plastic raditor cover.  i took those out and i put a pin in each
 <br>
hmm i have the RKSport carbon fiber radiator... <br>
BaggedCav98 wrote:i have the ones from pep boys, apc i believe.  they work fine.  if you open your hood there are 2 rubber stoppers on that plastic raditor cover.  i took those out and i put a pin in each
you CAN NOT mount your pins there with the invador hood. drill holes in your hood there and you'll be very disapointed. the rods for the pins dont reach long enough to get through the hood enough to pin if you put them there. i almost did it when i had the invader hood and realized it wouldnt work.  this is because the invader hood is higher right there in front of the extractor vent than the rksport extractor hood is.  with the invader hood you need to mount the rods under the rubber stoppers to the far sides by the fenders.
put them here:
 <br>
www.columbustuning.com    &    www.columbusracing.com
why do you say you cant do it when he has obviously done it? <br>
Cav_man2004 wrote:why do you say you cant do it when he has obviously done it?
thats a different hood. the hood he pictured is the rksport extractor, not the VIS invader. the VIS invader cannot be pinned in the front like that. its too high there.  <br>
cuz that's not an invader hood
I guess it would be more helpful if my car was with me instead of the shop but the rubber stoppers to the far sides by the fenders, I have f-1 fenders from A Plus can the pins still mount there... does anyone have a picture of the mounting spot? thanks <br>
Hey Adam do you have pics of where they pins are mounted under the hood?  I had the in the middle area on my old CF but I think it looks better on the outside like you have them.
Thanks <br>
Jenfur
do you have any more pics of where you pinned your hood??
"Remember do what you like because you have to drive it."--Me
