Suicide Hood DYI - Exterior Forum
ey guys i finished the suicide hood sat after noon just in time for the local show it was a big hit had quite a few people trying to figure it out ,also got some gurls asking me why i cut and weld on my car when its only 2 years old , but i got most of the fine tuning done on the hood mabie a few more need to be done but it looks great ,i also did a step by step DYI with photos on how i did it, the way mine is set up  is i still use the stock hood latch and i use hooks to hold the rear of the hood down  ,looks 100% stock from the out side and dont hit the front bumper can be set to stand at a 90 degree angle if you desire , so the question is who is interested in the DYI let me know pic wiill be up later today  <br>
2002 ls sport 15.600sec  1/4  88.2 mph "Turbo install in the process"
it all about love  and respect for the game if you dont have that find a new game
first of all its DIY (Do It Yourself) id be interested, are parts expensive? and how reliable are the hinges and latch and @!#$? and can you still pop the hood from the inside without trouble... things id like to know
 <br>
<ALIGN="LEFT">
<IMG SRC="http://ourworld.cs.com/W2Orchid/MOV01024_0001.jpg">
<watches>
I'm interested...
 <br>
Im very interested too. <br>
I'd love to see this
 <br>
MaximumBoost.net
1-888-TURBO-31
sales@maximumboost.net
TAX ID:  45-8013458577-3
thanks DooD for the corection, as for the questions  well it opens just like you normaly would your  stock hood except you only lift it about 5 inches then puill it twards you and it closes just like stock also the hindges are strong it just depends on how good you can weld ,i did all the fabrication myself all the support arms are 3/4" steel tubing with an 1/8" wall , my car is an eco  so i had to relocate the cruise control modual to the driver side strut tower other than that it all looks good ,and operates fine just gotta be a little catious while closing the hood into the rear hold down hooks as for it being reliable well the only thing the hindges have to suprot is the hood weight when its open the hold down hooks and stock hood latch is what hold the hood down during driving you can still open the hood from inside the car as normal and the pic will be up this tonight im going to pick them up right now  <br>
interested
 <br>
<img src="http://web.bentley.edu/students/m/mann_mich/nonpremium.gif">
Hmm... only a clam-shell hood?? Well, I guess I'll check out a DIY, I'd prefer a true Tilt-Forward hood, but I don't have a welder to re-locate the Latch. Clam-shell could work for now if I modify it to fit a fiberglass or C/F hood (when I have money to get one...) <br>
Hmm... I need a sig!
email me the info please
jrbyers96@hotmail.com
thanks.... <br>
listening on this... <br>
<img src="http://www.j-body.org/registry/americanred/JBO Sig.jpg">
That sounds exactly like the LeSabre hinge system.
Where's the pic??? <br>
Want a good deal and great customer service? Then check out
Tabasco Racing
PICS PICS.. ITS AFTER MIDNITE.. I DONT SEE EM... dang it man.. i wanted to see some pics of this.......bummer,
so whats wrong with this technique v/s the reverse your stock hinges to the front location and flip your hood like that?? just pondering on that <br>
<img src="http://registry.gmenthusiast.com/images/its2nv4/achop.jpg">
wal-mart messed up the pics so i had to have them re-done  as soon as i get them back they will be posted ,as for using your stock hindges it wouldnt work cause you gotta push the hood out and away from the front of your car ,and its close to the lesabre hindge but its not the hardware is alot stronger but pic soon promise they should be back thursday  <br>
Why didn't you just one hour photo them?  It's only 5 bucks at walgreens if you only get them on a cd.. <br>
NEW SIG UNDER CONSTRUCTION!!!
its2nv4 wrote:PICS PICS.. ITS AFTER MIDNITE.. I DONT SEE EM... dang it man.. i wanted to see some pics of this.......bummer,
His technique uses the OE Latch exactly as is. Moving your OE hinges to the front, even if done right, would mean moving your Latch to the back by the windshield. You
might be able to get away w/ the OE latch as is in the front if you use real hood pins, but I'm not positive on that. <br>
it is just like the lesabre hinge system.  hooks on the back, and the latch still in the front. looks sweet. im working on the same setup myself
 <br>
Click Here, To Check Out My Interior
Very interested here
03 drift cavy
pics??? <br>
mostly STOCK...not for too long '99 Cavy
Uhh.......update? <br>
2006 Cobalt SS I/H/E ZZP S2 HPT 2.8/60's Etc...13.8@105(I need to learn how to launch)
lies lies lies
 <br>
"Take that, rewind it back"................. "Just wing it!"
to do this parts needed is hood pins,stock hinges . remove the hood latch then move stock hinges to front and put the hood pins up by the wipers job done  1/2 day , no welding,  no fab of brace. btw stock latch can be moved to firewall but you will need to fab a mount for this.
  <br>
hey um havent been on the org for a few weeks, been to busy to play with the cavi or anything of the sort,found out im gonna be a daddy and all but hey i put the pic in my regestry i thought i did a post  letting you guys know the pic was done but i guess not  but just a few notes:
to the intimidator ,you cant just use the stock hinges and put them up front mabie if our cars had a flat nose and no radiator , see when you would tilt the hood forward on that idea the section of the hood between the headlights would go into the radiator suport, it would go suicide but only for about 3" ,but if you can pull it off more pwer to you ,any way check the pics out tell me what you guys think im re-doing the arms in billet aluminum this winter while the car is on its turbo install ill have more pics of the car the day before i park it and pic of me finishing off this years tires time for a smoke show  <br>
I am very interested and would appreciat it if you could email me the DIY instructions on the hood at.... Twiztidcavy@aol.com
Thanx,
Derrick Hudson
