any of you have a split hood kit installed?  if so, could you please post some pictures.  i'd like an idea of what kind of cut i should do.  if you havent heard of the split hood kit, check out the video clip
here
comments on this kit would be nice as well, or ideas of what kind of cut i should do.   thanks <br>
1997 Chevy Cavalier RS
<img src="http://www.fjear.us/signature.jpg">
just take the plasma cutter, smooth the edge, find a hindge and some weather stripping
 <br>
<ALIGN="LEFT">
<IMG SRC="http://ourworld.cs.com/W2Orchid/MOV01024_0001.jpg">
i was referring to a straight vertical cut, diagonal, custom swirve, etc etc =P <br>
your hood will leek in the rain.  this is not a good mod to do on a daily driver.  unless you had a resessed part that would sit under the middle of the hood and attatched to one side for water to run down when it rains.  otherwise it will leek. <br>
yeah... I had thought of the same thing.
It would take someone knowing enough about bending metal to build a groove at the seem to channel water, but it could definitely be done.
 <br>
<br>
Sig removed because some people cry too much.<br>
</a>Scott Heflin, President Team Forward Motion  <a href="http://www.teamforwardmotion.com" target="_blank">TFM </a>
id go with a curved cut down the middle
I am in the process of making my own now. Its totally made of fiberglass split in the center with a 1.5" lip overlap recessed in the center held all together with zeus fasteners. I will take some pics soon so i can post them.
