Anyone have Hp tuners for sale, Standard or Pro version ???
Boost Lover
Make sure you don't get an older unit make sure if you buy used that it is the newer unit
see ya!
go with the pro, if you plan on actually doing any tuning thats what you will need
I have a pro I never used. thought I lost it so I bought a new one.
Stardard version is perfect for me becaus i don't use 0-5v input and i never data loging over 5 minutes without laptop but Pro version do job also
Boost Lover
Rodimus Prime wrote:go with the pro, if you plan on actually doing any tuning thats what you will need
You can still log 5V inputs with standard, it just takes some extra ingenuity.
worthless nonsense that isnt worth the time and even if you did get AFR to log in that manner, you still cant log anything else, say if you have a ecotec and wanted to wire up a gm 3 bar map sensor to log boost, or you have a pyrometer and you want to log EGT also, you can log up to 4 inputs with the pro
But if you dont see the value in that, your prob not going to be that precise with your tuning anyway, so have at it
You can log up to two inputs with Standard, one through your AC pressure sensor and the other through your EGR valve. I'm sure you could find other inputs as well if you needed them.
Pro has it's place, no doubt about that, but standard isn't as useless as people make it out to be.
