Learned this weekend on two different cars that although we can put whatever we want in the PE commanded afr and multiplier tables, it will not actually command richer than 11.5. I guess for M62 set ups where you may want a richer mid range (say 11:1), it's up to a custom spreadsheet to get it dead on.
Has anyone seen a case where you can command richer than 11.5:1 on an ecotec pcm?
I guess I've never really tired to command that rich personally, but I swear i have seen logs from others that have commanded in the 10's......
P&P Tuning
420.5whp / 359.8wtq
I have seen commands in the 10's on my car, now not because I set the PE at that, but other fields we can't see commanding it.
Screaming for Mercy!! wrote:I have seen commands in the 10's on my car, now not because I set the PE at that, but other fields we can't see commanding it.
Yes i've seen that rich on very cold start up, or if you stall the car while logging (lol). I'm more interested in PE conditions though. I'll work the VE tables through the spreadsheet to get where i want.
If you guys see anything in PE less than 11.5 let me know.
oldskool wrote:Screaming for Mercy!! wrote:I have seen commands in the 10's on my car, now not because I set the PE at that, but other fields we can't see commanding it.
I was not speaking about cold start, or stalling. I was talking about PE.
I have not had the cold start richness that some have had on my car.
Screaming for Mercy!! wrote:oldskool wrote:Screaming for Mercy!! wrote:I have seen commands in the 10's on my car, now not because I set the PE at that, but other fields we can't see commanding it.
Oh? Hmmm. Have you seen it on 03+ ecotecs at all?
I think we saw it in Roberts car when we first started tuning it on the factory ECU and Alpha-N
I dont know why you'd want to run that rich anyways. My car does not like it and bogs like a son of a gun, and is noticeably slower on the but dyno than when I'm getting the 12.2:1 that I command.
Sponsored by:
Kronos Performance
what do you have as your base AFR for PE, im thinking maybe you change that lower to something other than 12-13 like stock, maybe you can only multiply so high off of it
I've tried base PE afrs anywhere from 11.2-11.8, with various RPM multipliers - 11.5 seems to be the floor.
Could always set to command 11.5 then use meth injection to reach lower that would get a bit complex though trying to do it in a set rpm range id think you would losing power going richer thn 11.5
Or command 11.5 and then import your high and low rpm ve tables into excel and do some math to make it richer where you want it.
Sponsored by:
Kronos Performance
I ended up doing just that, Leafy. But for other reasons than not commanding less than 11.5. Lol our cars "can" be tuned for an M62 on one bar, but the threshold into boost becomes a waste of fuel. At 25% TPS at a given RPM, i'm crossing into positive pressure, but am still stuck with the same AFR as WOT. I feel like it doesn't need to be 11.5-11.8:1 while it's just crossing into positive pressure, but i don't want it at stoich either lol.
So you already used the spread sheet. put your own custom taper in. Based on the VE map, yeah its the wrong way to do it, but @!#$ it it'll work.
Sponsored by:
Kronos Performance
