Hello everyone. Putting a megasquirt 2 pcb 3.0 together and if I am only running ms2 for fuel will I need a 2nd coolant temp sensor? Or is that only for standalone or datalogging?
Thanks
Jason
Yes you will need either the 3-wire temp sensor...one lead for the factory system and the other for the MS or you need to place a second sensor somewhere. To run MS as fuel only you will need a Tach signal, TPS, IAT, CLT, and an O2 (wideband). You can even let the factory ECU run the IAC until you feel comfortable to wire it up to the MS and give it a try. You can T-tap the TPS by the way. But the other sensors can't be T-tapped without running into problems. Tach signal can be had from the ICM(since your running fuel only, you will still have it) so all you need to do is get a new IAT somewhere an O2 in the exhaust and figure out what you want to do for the CLT.
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
I suggest using the 3-wire sensor just because it saves you time on drilling and tapping a place for the second sensor.
www.gmscf.com
^Add to that list a MAP signal, just a T-tap off a vacuum line since the sensor is internal to the MS.
Not running a heater core so I was gonna stick a 2 wire next to the egr where the water goes from the core to block
Jason
Where can we get said 3 wire temp sensor?
Joshua Dearman wrote:^Add to that list a MAP signal, just a T-tap off a vacuum line since the sensor is internal to the MS.
Unless you choose to run a GM MAP sensor. I don't see why people do that though, the internal works great.
Admiral Jedi wrote:Where can we get said 3 wire temp sensor?
Not sure on the part number, but you can pick it up from AutoZone or NAPA or anything like that. Not sure on the GM part number, but it's for a 93 Cavalier, with a 2.2.
You'll also need an extra TPS plug or something to plug into it.
www.gmscf.com
^true true. I like getting the 4bar MAPDaddy add-on and having isobaric correction. That's always nice, at least it was when I was in CA since I went to Yosemite and the beach all the time.
What kind of car? I just installed a ms2 v3.0 in a 2000 sunfire with the 2.2 (Not eco)
I ended up using a msd tach adapter for tach signal.
^that was a bad idea. The MSD tach signal is not a good tach signal for critically timed events. The tach adapter simulates a square wave based on when it sees the spark plug fire. Sounds fine, but what happens when you remember that the spark signal can be retarded or advanced from what is actual? I really wish MSD would make a mention of this with the advertisement of this product.
I certainly hope you're not using the tach adapter to run the MS on? I'm hoping that you mean you're running a tach on it.
www.gmscf.com
SHOoff wrote:I certainly hope you're not using the tach adapter to run the MS on? I'm hoping that you mean you're running a tach on it.
We cant help everybody......
Yeah, some people have it coming.
www.gmscf.com
