Does anyone have a megasquirt to sensor diagram as to what color wires on which sensors are tapped?
Thank
Jason
Not sure what exactly you mean. I'm thinking that since most sensors used with MS that the wire colors are usually the same (if using a pre-made harness). I bought a harness with mine, so for the most part it was straight forward. Just match up the colors. Colant temp was a yellow and black, IAC motor had all the same colors.
Other than that, just go to Megamanual.com and look around.
www.gmscf.com
