so i am looking into tuning software for the 95 2.2 and decided that i need a better tuning system for the car before firing her up, and have a few questions
1. i can use rt tuner with the ostrich for on the fly tuning, and the romulator as well as a definition file for the ecu
2. what else do i need to tune it? a chip and socket right?
3. does any one have a ecu definition file for a 95 2.2 ln2?
4. is there any tuning that i can do to this ecu without cracking the ecu case?
5. my car has no eprom right?
just looking to get into this to get a more accurate tune on the car and don't know much so trying to look to your experiances of tuning this set up
thanks
jason
The 95 has an eprom and memcal. I believe the Moates emulator will work with that ecm but you have to remember that the ecm is outside the car. Look for a thread titled something like "OBDI Tuning Project" by Chris Smyth for lots more info including answers to your other questions.
-->Slow
so what will the car probley do if i run the 440 injectors and a fpr idle high?
thanks
jason
jason norwood wrote:so what will the car probley do if i run the 440 injectors and a fpr idle high?
thanks
jason
Run realy rich.
Do you have a 3spd or 4spd auto. 3spd = OBD1 and a "burnable" memcal. 4spd = OBD2ish and not tuneable.
13.934 @ 97.82
ALL MOTOR
3 speed
hey cav fan where are you located in mi??? wanna help tune??
