Can someone make sticky for PCM/ECU pinouts for '95>??? It used to be in the New York J's library but they aren't up and running anymore...
^^Good info.
I also have access to the Eco pinouts and several others... I set up e-mailed replies, so if there are any requests, I'll put 'em up.
I would like the L61 pin out and the LSJ if you can get it.
Thank you!
Darryn
2004 Cavalier coupe, 5 speed, White
GO
Hahn Stage 2, Eagle rods, Wiseco 8.9, SS Valves, Dual valve springs, valve job, Ti seats and retainers
spec stage 3, Fidanza 7.5lb flywheel, Short Shifter
Slotted and dimpled rotors, EBC green stuff
SHOW
VIS EVO CF hood, KOBE KAM 5 17", Nexxen N3000, Ebay Black tails and filler, 5% tint
Gold line springs, Tokiko D-spec struts
ELECTRONICS
Kenwood in-dash DVD and Navigation, single Kicker CompVR
http://www.cardomain.com/ride/2974835
Let me find my ODB1 stuff and get it up also.
Kardain , I just noticed on your site. Where it says "LD9 PCM Outputs" that the link address
http://projectwyldfyre.com/pdf/99ld9/engine/pcm_outputs.pdf , says "99" ld9. Might want to change that to 97-98. The out puts show a 1 wire knock sensor and wiring for EGR , which are different on a '99.
Someone have Ion PCM wiring?
Gary, its a folder name that references "99", but I did add the description afterwards on the main page for 97-98 model year
Garrett wrote:Someone have Ion PCM wiring?
What year? I'll see if I have it (long shot though)
i need a 96 2.4 man pin out if anyone could help
i have 2001 so ld9 and ln2...if you want um jsut ask
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
I need pinouts for the 2.4L '00+ and the '99 2.4L. I can't seem to find either one.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
I attached all the 00' 2.4 pin outs
here.
I'll get the 99 one up in the next couple days.
Kardain wrote:I'll get the 99 one up in the next couple days.
Any update on the '99?
1997 GMC Sierra
2005 Honda TRX450R
Sooooo, a big bump of an old thread. Does anyone happen to have the pinouts for a 97 2.4 pcm? All the links in here are dead. Also figured anyone that might have them may be subscribed to this thread.
lafonjef wrote:Sooooo, a big bump of an old thread. Does anyone happen to have the pinouts for a 97 2.4 pcm? All the links in here are dead. Also figured anyone that might have them may be subscribed to this thread.
Yeah, links are long dead. The registrar I opted to use failed to notify when the domain was set to expire back in 2k7. It ended up getting reserved pre-expiration and snatched pre-expiration by an ad squatter.
I don't have the program I was using for pinouts anymore so current access to pinouts will be difficult, but I'll look in my site archives and see if something is there. No guarantees.
Gd autocorrect.. "snatched post-expiration"
I think I printed them out way back in the day...I'll dig through my old Cavy stuff and see if I maybe kept them.
1997 GMC Sierra
2005 Honda TRX450R
I'll look, but I think I only have the 00 files.
I can scan the 99 files out of my service manual if someone needs them.
