need to know if you can put a 88 pontiac grand prix 2.8 engine in the place of 3.1 liter ina 93 pontiac grand prix and what needs to be changed
Yes everything will fit and bolt up... get the ecu and just make sure there are the same number of pins.. other wise your 2.8 will run really rich
Honda's are like tampons, Every PU$$Y has one!!!
This is a very bad idea.
Why would you want to do this?
I <3 JGM
I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
In Loving Memory of Phil Martin December 14 2005
was able to buy a whole car cheaper than an engine
The 2.8s are complete junk. I had a 89 2.8 GP and the best part of the car was the Isuzu 5-speed.
"Project 69'"
1969 Chevrolet C/10, 1/2 ton, 2wd
-Boosted LS1?
-Richmond ROD 6-speed(will get sometime)
-Posi 12-bolt(built w/eaton posi unit and richmond 3.73 gears)
-Disc brake and 5 lug swap
+little extras
