Bad water pump-sounds like? - Other Cars Forum
Wednesday, September 24, 2008 7:36 PM
I've had this squeeking sound going on with my truck for a few weeks now. I figured it was the tensioner pulley because it'd go away as the truck warmed up. Also, it'd go away immediately with belt dressing.
I replaced the tensioner pulley today and it still makes the sound. My dad thinks it sounds like the water pump is about to go out. The sound still goes away after the truck is warmed up. There's no play on the fan.
Truck is a 2000 Dodge Dakota. Trying to sell it, so if it's a water pump going bad I want to get it fixed ASAP.
The sound is most comparable to crickets.
My only other thought is that spraying all that belt dressing on there and letting the belt squeek like it was prematurely wore out the belt..it's less than 1K miles old, but that seems far fetched.
Re: Bad water pump-sounds like?
Wednesday, September 24, 2008 8:29 PM
Spray WD-40 on the bearings of all the pullies. If you spray one and the sound stops, thats your problem.
"Project 69'"
1969 Chevrolet C/10, 1/2 ton, 2wd
-Boosted LS1?
-Richmond ROD 6-speed(will get sometime)
-Posi 12-bolt(built w/eaton posi unit and richmond 3.73 gears)
-Disc brake and 5 lug swap
+little extras
Wednesday, September 24, 2008 8:56 PM
Thanks, I'll give ti a shot first thing in the morning.
