General Motors will unveil a Chevrolet compact car at an auto show this fall, with production slated to begin early next year, say sources familiar with GM’s product program.
The vehicle will be built on the Delta compact car architecture at GM’s plant in Lordstown, Ohio.
The car will use a new 1.4-liter global engine that GM developed and recently announced in Europe. The turbocharged four-cylinder engine will be used in several GM vehicles worldwide.
The Chevrolet compact will not be called the Cobalt, says one source familiar with the plans. GM will produce the current-generation Cobalt through June 2010 as a 2009 model. It was unclear from sources whether GM will continue to build the Cobalt after that. The car’s engine will be capable of developing between 120 and 140 hp. Sources say mileage could easily exceed 40 mpg.
“It’s a pretty incredible engine; it’s direct-injected with great power,” the source says. “The small-displacement turbos make it possible to get great power so that GM might put it in the mid-sized products, too. It’s an extremely important engine and a very capable powertrain.”The new engine will be shared among five nameplates: Chevrolet, Pontiac, Saturn, Opel and Daewoo, sources say. That means the Lordstown plant could build cars for export.
The engine continues the trend that GM started with such cars as the Pontiac Solstice GXP and Saturn Sky Red Line. Those cars use smaller engines and high-technology devices such as direct fuel injection and turbochargers to boost fuel economy and performance. GM is retooling its plant in Lordstown for a new vehicle, sources say. Lordstown union officials have heard that GM plans to add a shift.
GM now is building between 1,400 and 1,500 cars a day at Lordstown; adding a shift would increase that output to 2,100 cars a day. GM builds the Chevrolet Cobalt as well as the Pontiac G5 and its Canadian counterpart, the Pontiac Pursuit, at the Lordstown plant.Meanwhile, GM is reconsidering bringing the Chevrolet minicar, the Beat, to the United States.
“The Beat for the U.S. is getting a pretty thorough examination now that you see what’s going on with fuel prices,” says a source close to GM’s product development. “It isn’t definitively on there as a go product, but there is a lot of inside chatter and it’s on the consideration list.”
>>>For Sale? Clicky!<<<
I was sabotaging Supra's by the local Toyota dealership when I over heard the friend of the gas jockey's highschool girlfriend that the new GM car will be a re-badged Yaris.
hope they keep the weight down on it too
and i think they are nuts for wanting to put that in a mid size car too
97cavie24ls wrote:hope they keep the weight down on it too
Agreed on the weight, but putting this engine in a midsize is not much different than putting an eco in a malibu or G6 - yea its a little underpowered compared to say, the 3.6VVT, but that's what base models are all about.
If this engine is anything like the direct-injected turbo engines out there currently, it should be a very adequate powerplant. It should have peak torque early and hold through most of the RPM range.
Yeaaaa for 40+ mpg...finally. Is this engine considered a part of the ecotec family or is this a whole new block?
from carscoop.com
General Motors has developed two brand-new engines for vehicles marketed in Europe and other regions, a 1.4-liter Turbo gasoline unit and a 1.6-liter Turbo natural gas unit. Starting off with the new 1.4-liter turbocharged 4-cylinder engine, it will be offered in vehicles worldwide starting in 2010 with outputs ranging from 120 hp to 140 hp and torque values of 175 to 200 Nm.
It is estimated that this unit will deliver an approximate 8% improvement in fuel consumption compared to a higher displacement naturally aspirated engine with similar output and will be EURO 5 compliant. The 1.4 Turbo variants will be manufactured at the GM Powertrain assembly facility in Aspern, Austria.
The 1.6-liter Compressed Natural Gas (CNG) turbocharged 4-cylinder engine that generates an estimated output of 150 hp and 210 Nm of torque will be introduced in the Opel Zafira minivan in 2009. The 1.6-liter CNG Turbo features a 25% lower CO2 value than a comparable gasoline engine and it will be produced in the GM Powertrain assembly facility in Szentgotthard, Hungary.
Looks like a Eco to me based of that 3d model
'the beat'
f that gay name.
Riddle me this... riddle me that...
