Hello fellow org members. I have been searching for a fix for a 2001 Grand Cherokee Laredo cruise control.
The problem is I can't turn it off. The jeep keeps on accelerating no matter in what gear it is. If I put it in park
the jeep runs up to 7k rpm!!!!! As I drive it home I have to stand on the brakes to slow it down and I cant get it to come to a complete stop. Does anybody have an idea how to fix it?
"Remember do what you like because you have to drive it."--Me
check the cruise throttle cable. sounds like it's sticking.
Desert Tuners
that or try disconnecting the battery for 15 min and see if that helps. im also i fellow wj owner i would honestly go to jeepforums.com and post it up there. you will get a lot more help from them on this question than you will here. no saying others here cant help but thats where i would suggest looking for a quicker answer
Thanks fellow jbody members. I will have to join jeepforums.com
definitly join jeepforums.com. Wealth of info on the WJ's
Might want to check the vacume lines as well
