stupid idea or no... - Other Cars Forum
Sunday, January 06, 2008 6:48 AM
ok...a really weird question...ive got a 06 ion 2.2 with a lot of money into it.(st.2 head from patriot and custom internals from a local speed shop)and i havent been able to drive in over 3 months bc i cant find a way to get extra fuel...
things ive tried so far and wasted a hell of alot of money doing it...
apexi afc2....i love this thing but in 05-06 we got a MAF sensor NOT a MAP sensor...so that didnt work...
ive also tried new injectors with the fuel pump out of my mini stock and the sms fuel rail with bigger fuel lines...didnt work
i dont know anything else to do...
the guy at the speed shop told me to buy a 04 computer and a map sensor then get aem ems...he said it would work, but then again he also said the apex-i afc2 would work too
2006 2.2-
st.2 patriot head
all forged internals...and it still doesnt run!!!!!
Re: stupid idea or no...
Sunday, January 06, 2008 8:28 AM
1(sic)ION wrote:ok...a really weird question...ive got a 06 ion 2.2 with a lot of money into it.(st.2 head from patriot and custom internals from a local speed shop)and i havent been able to drive in over 3 months bc i cant find a way to get extra fuel...
1) I hate the SAFC, but I HAVE seen it used successfully on MAF before, maybe you should give that another shot.
2) Why would you buy an 04 ECU to use AEM? AEM is stand-alone, it doesn't use the factory ECU at all.
3) You could just bump up fuel pressure a little (or down with larger injectors)...your idle would suck, but you wouldn't have to worry about destroying your motor in 2 weeks...it would just be 2 years instead
4) I <3 MegaSquirt
fortune cookie say: better a delay than a disaster
Sunday, January 06, 2008 10:21 AM
HP Tuners.
05 M6 YJ GTO 1 of 447 12.523@111.30
Sunday, January 06, 2008 10:43 AM
Sappy96 wrote:HP Tuners.
If you read their website, they only support PCM's with the LSJ and LE5 engines (2.0 & 2.4).
Sunday, January 06, 2008 10:57 AM
97-05 Chevy Cavalier 2.2, 2.4 2 6
05-07 Chevy Cobalt 2.0, 2.4 2 6
97-05 Chevy Malibu 2.2, 2.4 2 6
97-05 Pontiac Sunfire 2.2, 2.4 2 6
06-07 Pontiac G5 2.4 2 6
06-08 Pontiac Solstice 2.0, 2.4 (Automatic Not Supported) (08 2.4 Not Supported) 2 6
97-05 Pontiac Grand Am 2.2, 2.4 2 6
06-07 Pontiac G6 2.4 2 6
99-04 Oldsmobile Alero 2.2, 2.4 2 6
97-98 Oldsmobile Achieva 2.4 2 6
97-98 Buick Skylark 2.4 2 6
07-08 Saturn Sky 2.0, 2.4 (Automatic Not Supported) (08 2.4 Not Supported) 2 6
00-04 Saturn L-Series 2.2, 2.4 2 6
04-07 Saturn ION 2.0, 2.4 2 6
Unlimited Vehicle Group: not available
yep your right
Sunday, January 06, 2008 11:15 AM
Maybe you could give more details on your car? Is it turbo charged? If so what psi? Do you want to raise the rev limit? Or is this an all motor build and you have high compression pistons?
If your boosting like 5 psi or something you could get away with a safc but otherwise you need a real stand alone.
Why would you need to change your cars computer to run and AEM EMS?
I would recommend a Megasquirt set up if your poor, or the AEM unit or Electromotive Tec3 if you have some money.
Stay away from the E-Manage.
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Sunday, January 06, 2008 11:31 AM
I would check w/ hp tuners and make sure there is no 2.2 ion compatibility.
EFI live says they are compatible. efi live
Sunday, January 06, 2008 12:02 PM
Sappy96 wrote:I would check w/ hp tuners and make sure there is no 2.2 ion compatibility.
its an old issue thats been beaten to death since a year ago. there is no 2006+ 2.2 support from HPT
to the OP:
you could go megasquirt and bypass the factory computer altogether in order to control fuel. Thats the only way I could see getting passed the factory ecu's control.
piggy back's don't do it (apex'i, emanage, etc) but megasquirt does because it completely eliminates the factory ecu's control.
Sunday, January 06, 2008 12:16 PM
So use EFI live then.
Sunday, January 06, 2008 5:50 PM
Like the others said I would go with Megasquirt...
If you haven't already, check out http://www.ionforums.net
I'm on there, as I purchased an 07 Ion Quad Coupe 2.4L last August...
I miss her^
