[/url
ran a 10.74 @ 125 with 577hp/530tq
the parts:
* milodon 7 qt oil pan
* milodon oil pickup
* milodon steel dipstick
* ARP oil pan bolts
* standard volume oil pump
* romac lightweight balancer
* cammotion custom grind cam (dur: 234/228, lift: 564/560, lcs: 114, cl: 110)
* motorcraft lifters
* cloyes timing chain
* felpro mls head gaskets
* spec stage 3+ clutch
* sfi-approved lakewood bellhousing
* extended clutch fork
* masterpower 70mm turbo
* tial 50mm blow off valve
* tial 60mm wastegate
* bbk shorty headers
* two 2.5" v band clamps
* 3" v band clamp
* 3.5" flowmaster universal tailpipe kit
* two 2.5" j bends
* 2.5" u bend
* 3.5" u bend
* t4 flange
* two flowmaster reducers (from 3" to 2.5")
* 2.5" stainless flex joint
* diecast aluminum valve covers
* modified transmission mount (set motor back 1")
* oil filter remote mount kit
* temperature gauge (air intake temp)
* UPR solid motor mounts
* 4.125 bore TREperformance race prepped Dart 4 bolt main block
* TREperformance forged steel 4340 3.4" crankshaft for 363 (balanced with the rest of the assembly to a 28oz imbalance)
* TREperformance 4340 Forged H beam rods 5.315" for 363
* Clevite P rod/main bearings
* Probe SRS 2618-t6 high alloy lightweight forged pistons (-18.8 dished)
* Speed Pro high performance moly rings
* ARP head studs
* 3.5" to 3" and 3" to 2.5" silicone adaptors (for cold side piping)
* MMR front tubular a-arms
* MMR front coil over conversion (14" full race kit)
Link to full build
wow, thats a pretty badass build. love how clean everything is, especially going thru the bay/firewall. damn thats a clean install!
wow...i was never a foxbody fan thou im surrounded by them but man that is a extremely nice build
hell yea!! i want a fox body so bad....and this one is siiiick
very nice thinking about picking up the next cheap one that comes my way
