Here is my 150 dollars 03 sunfire.
I bought it cheap.The lad told me the the timming chain sliped.
I drove 12 hours to pick her up.
He said the valves didn't bump.I am ASE certified blah blah.
See watch he cranked it over and I was like hmmm ok.It sounded ok I guess.
I drag it home and unloaded it.
I had to put the fuel tank back in.That's fine I know I have a clean tank 2 year old fuel pump.So I look up on you tube about the rimming chain I found a short video put out from Cloyes.Hot Damn that's my kit.Mean while I waited to paid so I can buy parts.
 So I pull the seats to let the dank carpet to dry out.Fix left front turn signal.
Removed valve cover sure enough cams were off.So my next set was I busted out the
bore scope I'm looking for scars on the top of the pistons.None found on all 4.
Ok maybe the ASE monkey may have been right.
 To make a long story short it runs like a top
