Hi, I own a 1999 cavalier with a 2.2 liter engine. I am looking at replacing the fuel injectors. I found a great deal on a pair of injectors for a 1999 but they are made for a 2.4. Will these injectors be compatible with a 2.2 It's a stock engine no mods.
No, the 2.4 injectors have a higher flow rate. Like 20% more iirc.
Stock ln2 are 19 lb/hr I believe. 2.4 are 24 or 26.
It'd probably run; but not well without a tune.
I can look around the garage I probably have about 12 stock injectors laying around if you're in need. (They range from 70 to 100k miles but they worked fine years ago when taken off the car)
"A car just isn't a car without a little blood, sweat, and beers." -- Shadowfire
Thanks for the info, I'll manage to get some injectors.
