So basically im new to turbos, i want to put a turbo in my 99 z24 but i have no idea where to begin, is there a kit out for it? Ive seen kits for 98 but not 99, or should i buy everything seperate? And if so what all do i need to buy?
Also i would like to keep engine stock for the time being, but if not what all do i need to do to support a turbo?
I would do a search for turbo builds with the same engine on here, then read through the entire build till you get an idea. You can also read the stickies in the boosted section pertaining to turbos.
There are several good build threads here on the .org, look in the boost section for a thread named boosted 2200 build. Should be near the top. Although it's a different engine there is a lot of good info
on quality parts to get and it'll give you an idea of all the work involved. Also as stated above read the stickies in the boost section. There is even one that has a really good list for a "custom turbo "it".
Thanks for the info hopefully they can help! Been wanting to do this fora while
Look into tuning options first hardest thing for these cars!
Blue Boosted Penguin wrote:Look into tuning options first hardest thing for these cars!
And often the most expensive.
"In Oldskool we trust"
