I have access to all the parts I think I have a whole car for parts I wanted to know what all I will have to have to do the swap
are both the cars already 5spd? may want to check transmission forum. if going auto to manual i would think you need the computer, pedal set up, shifter set up. all the clutch components ( reservoir, lines etc) not sure about the mounting of the trans if it shares same location but i would grab as much as possible including axles etc. may be a good time to grab the engine wiring harness as well.
while you are at it it is popular to throw a v6 in there while you are doing it.
Are you just swapping a bad tranny out pr going from auto to manual?
I'm wanting to change from 3 speed auto to 5speed standard
