i have spent the past three hours searching on here for a write up on a five speed swap, and have had no luck!
I have two 98 z24 one convert with 5spd the other not convert auto. well the vert is totaled, my niece destroyed it! i bought the other with a bad engine, since the vert was just rebuilt less than 15k ago! I want to put the manual in while i have everything out cause it also has a new clutch and slave. can someone please point me in the right direction on how to do this? Would really appreciate it! Thanks in advance!
What is there to say? You need to swap everything trans related over... Im pretty sure the axles as well. Including the shift linkage, master cylinder, clutch pedal, etc.
Oh and the trans mounts are different so you will have to do some cutting and welding.
so, can i transfer the mounts from the vert? also, what about the ecm?
take the whole engine harness and pcm from the donor car.
And yes, take the tranny mounts, I think you might need to do some firewall cutting too. Just a small hole tho
Edited 1 time(s). Last edited Tuesday, September 22, 2009 7:43 PM
 do i take the harness thru to the inside of the car or just to the connection before it goes into the firewall?
This is a interesting topic,
I just finished getting project HELL FIRE running just need body work and 1 last thing,
2000 Grand Am ram air body full front clip
Grand am front brakes, hubs, control arms
Rear IRS conversion (done right) other guys set ups are not strong at all mine is
GTZ HO 2.3  5speed
OBD1 harness head to tail light
Cobolt lnf exhaust and fuel pump with a regulator
impala heavy duty bearings all round
GTP bbs style rims
list go's on
I sold the lnf engine so that never happened sorry if any one wanted to see that.
*ADVERTISING REMOVED*
Edited 1 time(s). Last edited Tuesday, November 27, 2012 12:35 PM
I'll be posting pics of the car in the following day's
So every one can see what car looks like now and during the creation of the AWD set up
