i can put new spark plugs in it everytime and it will fire up and run serveral times then will stop. also get codes P0122 throttle position sensor, p0335,and p0341 camshaft and crankshaft sensors codes while it is running and lack power ,surging on power. it is the
2.4 quad on a 96 sunfire. any ideas will help.]:->
Here is an idea, replace the throttle position sensor??? DUH???!!!
If that doesnt help, then replace the camshaft/crankshaft sensors... DUH!!!
they r all brand new replace them 3 times cam sensor crank sensor tps sensor
did you use electrical connection cleaner before you plugged in the new sensors? might be getting a bad connection, or you put one of the sensors in wrong...
GO PATS!!!
