hey i'm craig. I just turned 16 in november and just got my full licence and bought myself my first car.
Its a 2001 cavalier Z24 silver with sunroof
I dont no much about mechanics around cars so ill need all the help i can get
hope i found the right place and happy to be a member anyways
welcome to the site. theres alot of jerks on here but thats just how it is. you'll get used to it. everyone means good, just comes off a bit different.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
I dont mind any of that i just look for a little advice once in a while
on that note when i got my car the park brake and ABS light were
on does any one have any ideas why that might be
Hi Craig! Im Craig!
Check your fuse and speed sensor maybe for the lights.
Welcome.
Welcome. As far as the ABS and Brake lights being on, there are several possible causes. You should take it somewhere where they can retrieve ABS codes. (Not all scanners can do this.) A dealer can do this, but it won't be cheap as they charge a minimum hourly rate. My car had this problem when I bought it too. Turned out to be a bad ABS pump, which was an expensive ($1400) repair at the dealer. I hope that isn't the case for you.
i have the same light in my car. the stealership said it would cost $400 to fix
Did you get the light repaired or just leave it as is
welcome ... what region are you in?.
i honestly dont know how the regions are divided but i live in Nova Scotia Canada
Welcome!! post some pics of the car when you get a chance.
JBO Member since 2006.
hey hey another easterian canadian boy, welcome to the darkside man lol. im from NS too.
