What size are our:
oil drian plug.
gearbox drain (mtx obviously)
lugnuts
Also did u cars come with the cup type ashtray. '99
my trans plug is 24mm. I have the isuzu, or maybe it just has the wrong plug, idk. also 3/4 socket works also for 19mm lugs.
4bangerdeathsquad wrote:my trans plug is 24mm. I have the isuzu, or maybe it just has the wrong plug, idk. also 3/4 socket works also for 19mm lugs.
All the bolts on your cars are metric, while a 3/4 might fit. It is not the proper socket and you run the chance of stripping it.
Tinkles wrote:4bangerdeathsquad wrote:my trans plug is 24mm. I have the isuzu, or maybe it just has the wrong plug, idk. also 3/4 socket works also for 19mm lugs.
true. I'm just saying in a pinch. I've done it plenty of times.
4bangerdeathsquad wrote:Tinkles wrote:4bangerdeathsquad wrote:my trans plug is 24mm. I have the isuzu, or maybe it just has the wrong plug, idk. also 3/4 socket works also for 19mm lugs.
With all my schooling "use the proper tool for the job" has been drilled into my skull. I have improvised and gotten away and i also have been "bit" by it. It has become a preference/pet pev of mine.
I agree with you totally. right tool for the job. I just can't worry too much about 3/4 vs 19mm, because it's only a .002" difference, and also the lug wrench that comes in the trunk is super ill-fitting compared to a 3/4 socket anyways. I think I would worry if I had those lugs with the stamped steel cap over them, because they tend to get ruined easily, but I have solid ones.
i stand corrected, i was just trying to remember back to when i changed my clutch. i needed like a total of 6 wrenches, including a lug wrench.
Edited 1 time(s). Last edited Tuesday, April 08, 2008 6:12 PM
19mm = 0.748031496 inch
pretty damn close to me..lol
i use 3/4 cause all my impact sockets at home are standard. i also use 1/2" on the headlight bolts, otherwise i use all metric.
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
7 (or 8) mm, 10 mm 13 mm, 15 mm, and 19 mm are your major sizes used....
there is nothing close to 15 MM in SAE...
as long as you have those sockets, and torx bits, you should be able to do mostly anything
Edited 1 time(s). Last edited Sunday, April 13, 2008 3:32 PM
