ckick here
without heavy modification
tell your buddy to stop sniffing paint fumes
I like your friend. Hes VERY funny.
i seen a 32 v v8 in a volkswagen but it took a ton of fab work
Alex Patch wrote:Well I guess that answers my question then. lol. I didn't think it would go in very easily. On a side note 99redz i love your sig, I saw that episode its a good one.
It's not to say that it's impossible, a fairly common modification among Fiero owners is the swap for a northstar. Its a load of work any way you put it largely just because it's an engine swap. If you were planning on it, do it, just make sure you do all the research.
_________________________
HaHaHaHa yea right!!
That engine is soo long!!
You'd have to cut your car apart just to fit it in there!!
I doubt its much more work than a 3100/3400/3800 swap...
Except that the 3100, 3400, and 3800 are V6. A V8 would be longer, and the V6s are tight as it is.
Their not that much shorter than the northstar specifically. The northstar is small for a V8.
the approximate weight of a cavalier is 3700 lbs, and the weight of a fox body mustang is about 3300 lbs so why would you even want to put a v8 in a cavalier.
2005 Cavalier
VEHICLE SPECIFICATIONS AND DIMENSIONS
MPG (City/Hwy) 26/36
Wheelbase 104.1"
Overall Length 180.9"
Vehicle Height 54.7"
Vehicle Width 67.9"
Cargo Capacity 14 ft.
Front Headroom 38.9"
Front Legroom 41.9"
Rear Legroom 34.4"
Seating Capacity 5
Towing Capacity 454
Final Assembly Location USA
STANDARD ENGINE
Engine DOHC 2.2-Liter, I4, 16-Valve, DOHC, SEFI Front/Transverse Mounted With Horsepower Of 140@5600, Torque Of 150@4000, Aluminum Block and Cylinder Heads
Compression Ratio 10.00
Horsepower@RPM 140 hp @5600rpm
Torque Lbs. Per Ft 150@ 4000
Cylinder Configuration In-line
Valves per cylinder 4
Bore 3.38
Stroke 3.72
Engine Block Material Alloy
Block Head Material Alloy
Fuel Capacity 14.00 gallons
Fuel Type Unleaded
Fuel Delivery Name SEFI
STANDARD TRANSMISSION
Transmission 5-Speed Manual Transmission With Overdrive
Speeds 5
Curb Weight 2676lbs.s
Clutch type -
Linkage -
Heavy duty No
Overdrive Yes
OPTIONAL ENGINE
None
OPTIONAL TRANSMISSION
Transmission 4-Speed Automatic Transmission With Overdrive
Speeds 4
Torque Converter No
Curb Weight 0lbs.s
Standard Gross Vehicle Weight -
Maximum Gross Vehicle Weight -
Clutch type -
Linkage -
Heavy duty No
Overdrive Yes
2700lbs with 290hp/325torque?
I can't imagine why anyone would want that........
Who wants a fox body mustang?????
Sulu: We've entered orbit Captain.
Kirk: Lets go see what's down there. Scotty, Bones, Spock.....Ensign Smith.
Smith: Oh, crap.
Mike wrote:the approximate weight of a cavalier is 3700 lbs, and the weight of a fox body mustang is about 3300 lbs so why would you even want to put a v8 in a cavalier.
What are you smoking!? The LN2s wouldn't run below a 20 second 1/4 mile if they weighed that much!
i guess a cavi would weight 3700lbs if you loaded it up with a bunch of fat chicks. why would anyone want more power from their car, man what are we thinking!
SMILE!! YOUR ON CAMERA
its funny that your buddy said that cause ive kicked the idea around but i decided that it would be cooler to convert to rwd and rb26dett swap it
check the photos section it's been done.
this thread makes me laugh now
and from the looks of the thread in P&M there wasnt
THAT much work done to it (compared to other swaps)
(tabs) wrote:this thread makes me laugh now
and from the looks of the thread in P&M there wasnt THAT much work done to it (compared to other swaps)
Exactly my point.
