*2000+ clusters cannot be swapped with 1999- clusters (this is due to the BCM).
You can switch through 96-98 if they are mechanical, and 98-99 if they are digital. Apparently these are plug and play, but sometimes you have to find a cluster from the same year as your car to work properly (this is a quote from a previous post).
check around the stickys at the top of forums.
i can prob help you with locating a z24 cluster if you want. then you can put leds in it for whatever lighting color you want.
look at my cluster and what i did to it(it's in my sig)
*MSR 190 wheels not shown in sig.
http://www.myspace.com/fpsunfire
5 seconds to find another street...
i got a similar questions, with the led swap out, how can i swap my 91 sunbird cluster leds, how hard is it?
