New to Cavaliers - Newbies Forum
New to Cavaliers
Monday, April 30, 2007 5:25 PM
Alright I just bought a 95 Coupe with the 2.2L OHV I4 Engine. I bought the car from a kid who said it wasn't running and I got another engine with it that supposedly runs. Started thinking and took the plug wires and starter off of the spare engine and put on engine in the car and it turns over and tries to start but won't. I'm wondering if anyone might have any ideas as to what might be wrong with it. I'll get some pics later on of it to put up on here, but until then I need some help with this.
thanks and any reply would help at least should help.
Adam
Re: New to Cavaliers
Monday, April 30, 2007 8:42 PM
check for spark, fuel, and compression and go from there
Tuesday, May 01, 2007 11:16 AM
Plugs have spark but it's not real bright blue it's kinda a yellowish color. Would that be the ignition coil or plug wires?? It also seems to be getting gas but am planing on getting a new filter and pump anyway.
Tuesday, May 01, 2007 3:33 PM
check your coil pacs
Tuesday, May 01, 2007 3:48 PM
Not to sound dumb, but how do you check them I know they are on the back of the engine but I have never had an engine with coil packs. All of mine have been carburated with distributors so I need some info on this.
Thanks
Thursday, May 03, 2007 2:31 PM
yellow is bad. You already tested them and they're bad. I would replace the coil packs regardless. probably get some cheap on ebay.
Sunday, May 06, 2007 12:45 PM
kool but i found out that my fuel pump isn't running when I turn the key to on. So I am gonna check on that first then get the couls.
[IMG]http://memimage.cardomain.net/member_images/10/web/2638000-2638999/2638819_3.jpg[IMG]
