Do they have you create a username... then put your full name with your posts??? I'm a little pissed...
2012 numbers - 4SPD
AUTOMATIC!!
Roy Phillips wrote:Do they have you create a username... then put your full name with your posts??? I'm a little pissed...
You can change that in your profile. Go to your "control panel" up above and then click on "Edit your Profile". Just delete your "last name" and put whatever you want to show up as your name in your "First name" slot. Simple as that.
My Fquick Page
I had the same issue. Rather than fudge your name as Jason suggested, you can do the following:
Under Control Panel, in the forum section, click "edit my forum options"
Then under the global options section, in the "author" line, fill in the name you want to appear with your forum messages.
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
Geeky wrote:I had the same issue. Rather than fudge your name as Jason suggested, you can do the following:
do what he said. jason's method will get you warned or temp banned. yes, lots of people have a fake name in their profile. however, unlike you, they aren't drawing attention to themselves by posting about it.
GO PATS!!!
you're required to have your name in your registry as per the site's Terms of Service:
http://www.gmenthusiast.com/terms/
to change the name that is displayed when you post (your author name), follow Geeky's instructions.
awwww!! ^^^^^^^^^^^ What happened to Bender?
