I was just looking at installs for the AEM CAI for my 2004 cav. It was messed. So I went to my car and looked under the hood.
I noticed there is like 1000 things going from the intake to somewhere else on the car. For real there is like 7 things. If I bought an ebay intake does it have the hook ups for all these things. It seems like the best thing to do is to get an expensive intake so that I dont have to worry about where all these things clip to.
If you have seen the AEM CAI install you know what I'm talking about.
I have a 2004 and an AEM intake... there are really only 2 things going to it... the intake air temp sensor and the line going into the valve cover for venting purposes (onto which a filter can be attatched if so desired)... the rest of the connections to the car are simply anchor points so the intake doesn't move around...
looky
Edited 1 time(s). Last edited Thursday, September 28, 2006 12:55 PM
you'll also shed about 10 pounds of the cars weight, that stock stuff is heavy.
-Chris
when I went and looked under my hood I seen the IAT sensor and the valve cover hose thats mentioned. But I also seen 2 small things going from places on the motor to around the same area as the IAT and valve cover hose. If you don't know which 2 little hoses or whatevers I'm talking about I will try and take a picture.
this is from my 2003 Cavalier
from left to right......
- connects to the fuel rail
- connects to the engine ( but like mentioned before can be replaced by a filter, like mine )
- IAT sensor
those should be all the things that ou need to reconnect
CaviFL45
ya i figured it out. there was only three not 4. and I see........ i completed it.
