Didn't know where to post this so i posted it here. I got Grillrds old hood the Turbo sport one from ClassGlassperforamce.com. WEll i was wondering how much of a difference it would make to make a ram air style intake to fit that hood? Like the WRXs i believe have something like im after. Just something that comes off the TB into a flat pan type thing with an air filter right under the scoop. Would it be worht it?
the only time you see a performance gain with a ram air set up is around 100mph.
El Fuego ( the grounded one ) wrote:the only time you see a performance gain with a ram air set up is around 100mph.
And 8 MPH after that you hit the cut off
so basicly its not worth the effort
air from outside the engine bay will most likely be cooler always.....not just after 100mph. Think about it, free flowing cooler air passing over the hood is going to be better than air in the engine compartment that is warm from engine operation.
Just make sure that if you do decide to do this you have some sort of system to catch the water when it rains....otherwise you wont have a motor to ram any air into
Hell might be a fun project as a track only setup!
2007 GM Tuner Bash...HELL YEA
PA,MD,NJ,DE,NY and all states north caravan
you i know that but i saw soemthing simialer (sp?) to that on another car dont remember what tho. The colder air over the hood is what i was trin to get at.
jWagg wrote:just take your hood off.
the aerodynamic loss will negate any benefit from doing that...
