Okay, I disconnected my battery in order to do a couple things on the car. #1 I removed the tuner tube #2 I removed the BONG #3 I put in the lower motor mount #4 I hooked the battery back up and waited 15 minutes.
Then I fired it up and after I put it into reverse it blinked my lights and the service engine light comes on. I turned everything off. Unhooked the battery again. Checked the sensors and I realized that my intake sensor was loose and almost out. I plugged it back in. Waited 15, then hooked up the battery again. It still does the same thing. Is it a misfire with the computer codes? I can't seem to figure this puppy out.
Thanks for all and any advice on the issue.
go to autozone and have the code read
Just out of curiosity, did you forget to plug the IAT sensor back in? It sounds dumb but I forgot to the other night when I was working on my car and tripped the CEL. The sensor was still in the intake but I forgot to hook it back up to the harness
