easiest way to cut metal? - Newbies Forum
Friday, May 19, 2006 8:54 PM
so i need to cut off like less than an inch of a 1/2"diameter metal rod... what would be the easiest way to do this?
help please?
Re: easiest way to cut metal?
Friday, May 19, 2006 10:16 PM
hacksaw or better yet just use a reciprocating saw..... u know a sawzall
Friday, May 19, 2006 10:32 PM
Angle grinder with a cutoff wheel.
Friday, May 19, 2006 11:11 PM
easiest? plasma cutter
Saturday, May 20, 2006 8:48 AM
using any of the above methods you could have done this task in the time it took you to walk to the computer and post this. and the only easier way than using the plasma cutter is buying the rod to length.
Sunday, May 21, 2006 11:50 AM
a cohp saw with a steel cutting blade works well.
http://registry.gmenthusiast.com/images/my2005cav/my%20car%20the%20bash.jpg
Sunday, May 21, 2006 10:40 PM
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]easiest? plasma cutter
damn, beat me to it...
get a dremel, you'd be surprised at how many uses you'll find for it.
Monday, May 22, 2006 5:55 AM
cannon fodder wrote:[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]easiest? plasma cutter
me 2... and good call on the dremel. dremel with a small cutoff wheel is a perfect combo for little things
Monday, May 22, 2006 6:08 AM
We've got a nifty reciprocating hacksaw at work... clamp the work in, turn it on, put it in drive, and go do something else while it does the work for you.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
Monday, May 22, 2006 7:20 AM
I use a dremel to cut metal quite a bit. Just get some of the little cutting discs and make sure you wear safety glasses when you cut since the discs tend to break and go flying.
Rob
Sold 2/2/05
Tuesday, May 23, 2006 1:46 PM
HAH !! Plasma cutters and sawz alls are no match for the mightie......
CHUCK NORRIS
He slices he dices he minces and chops hes like a human Ginsu (sp?)
