my left turn signal (front and back) and really screwed up. they blink about 3 times faster than my  right signal, my front left is also out, i dont no if thats is related to the speed problem tho. i have no idea how to fix this, please help me.
Relay.
~The Confused One~
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
<A HREF="http://www.sandstorm-j.741.com" TARGET="_blank">Pictures and More</A>
the rapid flashing is due to a bulb being burnt out.   goto the parts store andpick up a pack of bulbs.  ask at the counter they can look em up and tell you what number you need.  and replace the bulb.
what is a relay? or can i jsut change the bulb and pressto, its fixed?
Forget about the relay.  Just change the bulb.  That should fix it.
If it doesn't, then you can look into other stuff like the relay.  A burnt out bulb will cause the rapid flashing though, so there's about a 95% chance that's your problem.
