got a question when i drive down the road my front tires sound like they're running over where a tractor has drove or those rumble strips that are on the outside of some interstates.  and when i drive down the interstate goin 70-75 jesus does it sound bad and it rattles sh*t inside  rumbles like i'm rollin on 44" superswampers and it only gets worse as i go faster
also its not a constant noise really more like a (ruummmmmmmmruummmmmmmmmruummmmmmmm) more like a repetition
maybe they are out of balance
couldn't tell by your profile, but do you have directonal tires, and you got the fronts switched? if not that, then must be ballance....
make sure you lug nuts are all tightened.
slight chance of a worn wheel bearing.
1979 Impala Sport Coupe Aeroback
could it be that the camber is off because it's lowered, i had a bent rim but i changed that and got it balanced not too long ago and still does it and no they're multidirectional goodyear rsa's
No, lowering doesn't cause camber issues on our cars.  In order to have camber issues, you'd have to lower it beyond any reasonably drivable height.
I had something similar happen to me last month, it was more of a vibration, it felt like the tire rubbing up against something.  It turned out to be the drive axle, but it is tricky to diagnose, almost the same symptons as a wheel bearings.
I put the car up on axle stands, took both the tires off and I got my buddy top sit in the car and run in to about 80km/hr, then i compared the two sides and it looked liked there was a slight vibration from the driver side drive axle.  I guess we got lucky diagniose it.
good luck
got brand new cv joints about 5-6 months ago and nope brand new tires as well when i bought the car a year or so ago and they aren't worn bad at all....... this is wierd i can't seem to find out what it is?
i say wheel bearings are going
if the vibration is noticable at all speeds its in your drive train( bearings, cv, trans). IF not  and only at high speeds its in your tires.
