it  says that its for a 98-01, but  i thought the engine lay out was the same from 98-02. i could be wrong.
dunno.. post the ad... also with the rubber connector. the bottom end of a honda accord CAI will fit a cav if you remove the air box..
1997 Cavalier Z24 4Spd Auto. Magnaflow dual exhaust.
the add is from e-bay, and it says its for the 98-01 cav. i heard on here that the  2.2 engines from 00-02 were the same.
should, the seller just may have the wrong years.
-Borsty
I figured that it fit , just wanted some help to be sure. thanx.
should be 98-mid02 since the ecotec came out in mid 02 the seller probably didn't wanna confuse someone that had an eco (since it's also a 2.2l) into buying it and then pissing and moaning about it. just a thought.
SO EVERYTHING!
