Hello , and good day to all j-body members. I have a 1988 Sunbird which seems to have a leak, every times it rains I have a pool of water on the drivers side floor board. The water is coming from behind the dash board, when I did a further inspection its coming from the top of the fire wall compartment where the drain for water and rain is located  under the wiper arms. The is also a plastic housing cover for the blower motor door, the seal seems to be detoriated and I assume thats where the water is coming from because I can see light inside the car.
if you can see exactly where the seal is bad and water is leaking in, you can probably get some silicone sealer and patch that up.
i had a problem with that in my cavy- and that drain under the wipers was cracked, and i just siliconed it- no more water!
No, my friend had this problem .. they said it was something like the anti freeze tank or damnit.. i cant' remember LOL i will post it later on tonight when i get around to ask him.. SORRY but its something like the heat absorber for the antifreeze or something.. DAMNIT! i will get back to you on it... Master something... damn. o well sry!
^master clyninder?????????
aaaaaahhh............. ok?
-Borsty
No its the Heater Core, Your heater core has gone bad.. You need to have that checked out ASAP, but thast what it is.. its the HEATER CORE!
^^^ erm kinda doubt that unless he has antifreeze on the floor.  I've had this problem (water leakeage) and I've also lost a heater core in my 1st/ 2nd gens.  The water can come in from different places, windshield, top of your door, through your door if its rusted out.  Just look around and find the leak and silicone it or get new weatherstripping.  As for your heater core if it goes you won't have any heat and you'll lose coolant.  Plus your leaking "water" will be green and smell pretty lol.  When mine blew it spilled out onto the pavement but I guess its possible it could leak into the cabin.
<img src="http://www.geocities.com/fudd_22602/elmer-shoot.gif"> Old school Js rock
Its not his heater core he said it only happens when it rains...
besides if it was a the heater core like fudd said it would be green and smell like dirty whores duce.
1979 Impala Sport Coupe Aeroback
some of the older grand am's had a known leak on the drivers side lower windshield, the seal on the rubber goes after a while.
