MRThompson (jrthompson) wrote:BuiltNBoosted wrote:id be careful with the trans wires. i think thats what jason narrowed his trans problems down to. i think the block needs to be painted silver as wellgranted it will get dirty but that trans looks amazing. and do i spy a turbo on the motor next to the trans?
jason has an automatic too. i don't think teddy will have that problem. also the automatic ecotec wiring harness have ground problems from the factory. hard to explain but spent 6 hrs chasing it.
teddy- looks good as always. silver was a wise decision. and why is the turbo sitting on the wrong motor? lol
Teddy wrote:MRThompson (jrthompson) wrote:BuiltNBoosted wrote:id be careful with the trans wires. i think thats what jason narrowed his trans problems down to. i think the block needs to be painted silver as wellgranted it will get dirty but that trans looks amazing. and do i spy a turbo on the motor next to the trans?
Thanks guys!
The Snail is sleeping on my spare motor for now, I have another bare block which I'm currently building that it's going on.
I finished the harness tonight, its looks way better now that my fuse block is extended to under the dash, I made 3 main harnesses, one that runs behind the brake booster, along the back of the block up to the Ignition module, Coolant Temp, evaporate solenoid and the #1 o2 Senor. the 2nd harness goes under the transmission which plugs into the speed sensor, 2nd o2 sensor, and the reverse lamp switch. The last harness runs under the intake and goes to the fan, knock senor, oil pres. switch, cps, injectors, IACV, and the TPS.
I think i know of the ground issue your talking about, the stock harness has three small and one large ground wires that are pinched together using a metal clamp. as I had my harness completely torn apart I could see a ground wire that had been cooking out of it's casing, yes, the insulation had melted off more than 12" from the clamp. After diagnosing the problem it would seem the issues was with the metal clamp being loosely pinched therefor making a bad connection, causing resistance, heat, etc. I replaced the ground wire with a heavier gauge, soldiered and heatshrinked the wires together.
The last thing to do now is hook up the battery, I'll let you know how that goes tomorrow in the day time.
Mike, I've done this so many times... lol I timed myself last time i did this and i was able to do in 50 minutes. It takes another hour to put it back in, bleed the clutch and fill the coolant. Even though I'm working behind my garage, I still use air tools and ratchet wrenches.
Stephen (manta z) wrote:BuiltNBoosted wrote:MRThompson (jrthompson) wrote:BuiltNBoosted wrote:id be careful with the trans wires. i think thats what jason narrowed his trans problems down to. i think the block needs to be painted silver as wellgranted it will get dirty but that trans looks amazing. and do i spy a turbo on the motor next to the trans?
teddy- looks good as always. silver was a wise desicion. and why is the turbo sitting on the wrong motor? lol
but jason did another harness to another car and it was messing up the trans too. so id just be weary of it messing up the trans is all.
both were automatics, so that is not to say a manual will have issues where the computer has really nothing to do with the trans. just my thought though. wont know till someone tries.
Ryan suddick wrote:Looks good. Tub your wheel wells while your at it to make it all look smooth instead of all thise corners and angles. Other then that I love your engine bay.
MRThompson (jrthompson) wrote:i love it.![]()
i think after i get another beater. i will be pulling my harness back out.
gmanz24 (The Bash Whore) wrote:MRThompson (jrthompson) wrote:i love it.![]()
i just fully tucked my beater before i even started on the car with the built motor
Stephen (manta z) wrote:im surprised you haven't ditched the EVAP stuff to get rid of the solenoid next to the ICM
Philly D wrote:Stephen (manta z) wrote:im surprised you haven't ditched the EVAP stuff to get rid of the solenoid next to the ICM
How do you go about that? And is there any codes set from it?
