just as the name says pic request - 03+ cavalier with quick release hub and after market steeringwheel
thx
I've got the momo hub and NRG quick release and a Sparco wheel, if I can find a charger for my camera I'll snap a few for ya.
I'd suggest you do some research on the issue with the 03-05 steering wheel splines/shaft diameter before you may end up disappointed.
^ i have a momo hub on my 04 with no problems
stock eco with 110 shot <<<<<<<<<WTF???
Cody@RDFabs.com wrote:I'd suggest you do some research on the issue with the 03-05 steering wheel splines/shaft diameter before you may end up disappointed.
Yeah I discovered this difference when I attempted putting my 01's steering wheel on the 04's tilt column.
I've had mine a little over 2 years and not a problem.
Well the issue is, somewhere in 2003 model year GM switched the shafts overall diameter making the momo hug adapter not fit.  For some odd reason, there are a rare few 03's and the above 04 are somehow been really lucky. My 03 donor car had tilt steering and I wanted it in my 99, but i'm not running an airbag so i was quite disappointed when i found out my 03's had the larger diameter shaft.
Could it be the tilt steering column is different from the non tilt?
_____________________________________________
94 Honda Del Sol
^^maybe on the 03+
my 02 is a tilt wheel and i'm running the momo hub no problems.
my 05 tilt didn't work....so i swapped the column
05CaVaLiErBaRkIn3Rd wrote:I've got the momo hub and NRG quick release and a Sparco wheel, if I can find a charger for my camera I'll snap a few for ya.
almost exactly what ive been looking at just a momo steering wheel instead
