I finally got my Tokico d-specs & Tein s-techs installed, I was just gonna go with stock struts, but got talked out of it, plus found a good deal on some d-specs. I'm happy with the outcome, I do wish the rear would've lowered a little more, but it works for now.
Before...
After...
Phewe's for president!!
Front...
Rear...
Respect...
My stubby...
Probably getting the RK sport bezel off a fellow member, so I decided to have som fun with a can of nightshades, the sun created a wierd glare,
I have a set of Roja rims going on, just waiting on rubber.
Comments welcome.
Looks great!
I have the same set-up. I have my d-specs set at 3.5 turns for that "go-cart" feel.
I like the raked look.
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Looks good.
Nice, glad to see some pics of the S-Techs. I was debating on H-tech or S-Tech springs to go with my D-Specs. I think I want S-Techs.
What drop is s-yech springs?
98 j-body sedan
Car look good man
S techs: 1.7 front and 1.3 to 1.5 in the back.
Looks good, but just a HAIR high in the back for my taste. Should look killer w/ rims on.
this is a pretty old post but you can cut 1 loop off the back s techs. i have s tech and cut one loop off the top of rear for couple months now with stock shocks and same comfort, and all. it evens out the rideand looks are better. look under "cutting spring" post under suspension, theres pics. just a litttle .02cent
instagram: peru_stylez
CHINO wrote:this is a pretty old post but you can cut 1 loop off the back s techs. i have s tech and cut one loop off the top of rear for couple months now with stock shocks and same comfort, and all. it evens out the rideand looks are better. look under "cutting spring" post under suspension, theres pics. just a litttle .02cent
This is one of the worst ideas Ive ever seen.
JGM T-SHIRTS!!!!
In Loving Memory of Phil Martin December 14 2005
Alexis: Dustin, you're ghey, lol. I am better. I have tits, and tits rule all.
You'd be better off putting a heavy sub enclosure in the trunk...safer too.
Lol@name&techniquecoincidence
I SATCHMOE YOU!!!! wrote:CHINO wrote:this is a pretty old post but you can cut 1 loop off the back s techs. i have s tech and cut one loop off the top of rear for couple months now with stock shocks and same comfort, and all. it evens out the rideand looks are better. look under "cutting spring" post under suspension, theres pics. just a litttle .02cent
actually i had the same problem with my sportlines... and when i called eibach they said it was acceptable to take no more then one loop out... but up too one was fine. i still didn't do it tho, just sayin.
