Shifted wrote:Its actually quite a bit more than a megasquirt can do, plus you have a base tune to start with (stock file).
thats what I was going to say...... all these other stand alones, you have to come up with your own base just to get the car running. Then figure out how to tune it. This is your car already running...... with easy to use menus to help you change what you want to change. I've seen the Electromotive Tech II stand alone, and you have to start from scratch.
plus its about the same price, or cheaper then most systems.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
I find it very humorous that HP Tuners decided to use the same enlosure I used to prototype a personal MP3 player for my Computer Engineering capstone project (you can get them for free as samples from www.pactecenclosures.com). This kind of disappoints me. Considering the unit is 650 bones, I would of expected a more rugged and professional casing for the physical product.
Regardless, it's good to see this thing is now in the open and available to purchase.
I will NEVER change my sig. HTML 4 EVA!!
First of all your not paying for just the hardware, your paying for all the time theyve spent engineering the software. Second of all Im sure they use a generic enclosure and off the shelf parts for their hardware because it helps keep costs down. If they had to pay someone to produce a proprietary enclosure Im sure it would cost $$$$ more and I dont plan on using the box on a Dune Buggy.
Mr. Pute wrote:I find it very humorous that HP Tuners decided to use the same enlosure I used to prototype a personal MP3 player for my Computer Engineering capstone project (you can get them for free as samples from www.pactecenclosures.com). This kind of disappoints me. Considering the unit is 650 bones, I would of expected a more rugged and professional casing for the physical product.
___________________________________________________________________
15.149 @ 91.26mph 3-18-2006
At this point, I don't care if it's an old Kleenex box with some wires hanging out of it... if it does what it's supposed to and doesn't crap out on me, I'm happy.
Ad1kTed 2 SpE3d wrote:Shifted wrote:Well, this has the advantage of a NO WIRING INVOLVED standalone basically. As far as shifts go, you can set the shift points and trans pressures wherever you want them, you can even lock the TC if you wanted to (will break things).
So.....Is it basically a Mega-Squirt minus the complicated wiring and putting it together?
Yeah Im starting to ( I belive) get an idea where the stand incomparison. so far what Ive come up with is that nither are really miles apart from each other. there both pretty decent. with ups and downs. ms is about half the price, but youve got headaches in front of you (trust me on this one)
the Hp is a bit more expensive but looks to be worth it.
really gentlman it comes down to this. you are paying for a nice clean AF line. no matter what you run SC, Turbo or nitrous (<----I dont know about the HP on the last one but MS does
when it gets right down to it its just another question of what you want to spend and how much you want to do.
Im a level 32 joedm newb flamer.
YAY! for kleenex Box, frick I can't wait till they support s/c reflash. Any updates so far shifted? You're one lucky SOB,
Anyone have any idea if this will work on the Cobalt SS S/C? I looked at the site but it just says gen 3 & gen 4 GM...
Waiting for updates......I knew it was coming, but I'm still surprised it's finally released.......
Just an update
I spent about 5 minutes with it today, set up my ECU for the larger injectors (42lb/hr), have 35 PSI in the rail...
Well last time I started it up (before HPT), the car BARELY ran. It was so rich that it was fouling out the plugs and misfiring. It was actually spititng raw gas out the tailpipe, along with a thick black cloud leaving carbon deposits on the pavement.
Well about 5 minutes with HPT after figuring out what the numbers mean, SHE IDLES LIKE STOCK, with 42lb/hr injectors. No smoke, no missing, no gas smell.
Here's a screenshot from when I was flashing the ECU:
I haven't been this excited since I actually put the turbo on my car
soooooooooooooo gangster, more pics!
SpeedRacerZ wrote:its amazing how people can post on these boards, but yet can't read
what good does it do to post replies if they cant read them?
Time to come down for that trans swap Shifted
so that means this wont work for my 2000 s/c auto trans
dam it to hell , damit it all
LOL J/K
this is freakin sweet
Shifted wrote:Well last time I started it up (before HPT), the car BARELY ran. It was so rich that it was fouling out the plugs and misfiring. It was actually spititng raw gas out the tailpipe, along with a thick black cloud leaving carbon deposits on the pavement.
Wow.
Thats the best thing I have heard besides "you wont believe this but..." from Ryan (cavattack). Now the garage wont smell up the house with nasty fuel fumes. I cant wait til his comes in and I can quit hearing about uel issues and his fuken FMU!
do you have pics as far as editing injector size and duty cycle. im interested even on what was changed to the stock map appose to the map on now with the 440s and idle.
how did u change the duty cycle and whatnot awhile at WOT or higher throttle. any screen shots?
damn thats sexy, cant wait till mine shows up
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
am i the only one that tried to press the buttons on the screen shot and got pissed because it didnt do anything?
lol j/k
well, im glad you know what all that mumbo-jumbo means... haha.
never said i knew what it meant. lol
Wrench Monkey wrote:am i the only one that tried to press the buttons on the screen shot and got pissed because it didnt do anything?
lol j/k
lol no your not the only one....god im such an idoit....this thing looks amazing.
BlackEco wrote:First of all your not paying for just the hardware, your paying for all the time theyve spent engineering the software. Second of all Im sure they use a generic enclosure and off the shelf parts for their hardware because it helps keep costs down. If they had to pay someone to produce a proprietary enclosure Im sure it would cost $$$$ more and I dont plan on using the box on a Dune Buggy.
i should of said my point behind bringing up the quality of the physical parts is that I would be absolutely livid if the thing stopped working in a year due to a bad solder joint or something stupid like that. $650 is a ton of money to spend on something that is presented so horribly in my opinion. Of course, I'm still going to buy it though...
Oh and the programming involved with the software isn't bad at all since they're using the same VCM suite they have for the F-Body platform. The only hard part is getting access to what GM had already done by means of knowing the encryption on the ECU, which probably wasn't that big of a problem due to the fact that they've done it in the past for the F-Body platform. If I had to guess, if you cracked open that Pactel case, you'd find an interface made of a usb integrated circuit and either a Atmel or Microchip microprocessor acting as the interface between the computer and ECU. Nothing more than $20-$50 in physical hardware.
It's safe to say that they bank REALLY good on the products they offer.
