I recently discovered that my dash pad is cracked and want to know if a 4dr dash pad would fit into a 2dr for a cavalier
ya, it will fit
yeah and cav dash 95+ will fit
<img src="http://www.tabascoracing.com/images/splash_01.jpg"><a href="http://www.tabascoracing.com">
ok thanks guys.....
are the 4dr dash the same as the 2dr dash? Shape wise and everything because I know that the window is different!
My dash pad is cracked in my 2dr 2000 cavalier and I think I can get a 4dr dash pad for real cheap!
There's no difference in the dash pad (the vinyl portion) from 95-05 coupe/sedan style Cavaliers.
The problem though, is that I'm having problems imagining your dash pad cracking. Are you sure it's not the dash itself? Because the dash itself is different (95-99/00-05), and the dash includes the strip directly next to the window.
Interior FAQ -
J-Body of Michigan -
^^^ good point
i am sure, see i got the pad from a local junk yard and the donor car has blown air bags, sell when the air bags blew it must have cracked the plastic under the vinyl, and not the now air bag cover sticks up a little bit above the vinyl
