Dash/radio bezal if I am swapping my car to a 2k engine and interior wiring harness?
I had a custom radio bezel made for my 97 before I knew I would be wiring my car to a 2k+.
Thanks.
Yes you can.
Just dont swap the dash out.
Want hub spacers rear disk brackets or trailing arm bushings? Shoot me a PM.
Ohhh duh, I just didn't know if the wiring was different calling me to use the 2k dash! Thanks homie, Hey hittn the yard tomorrow for your axles.
Only difference in wiring is the radio. Everything else is plug and play. GM did a couple things right with these cars over the years.
finally going to use that bezel, huh David?
you will have to run a 2000 up cluster, so u will have to fuss with the lower dash to make it fit in the pre 00 dash, but can be done yes
I'm running my 99 cluster in an 00+ sunfire dash, so yes you can run a 99 cluster in the newer dashboards. Just a little trimming and you're set.
Club Teh Jeffie wrote:I'm running my 99 cluster in an 00+ sunfire dash, so yes you can run a 99 cluster in the newer dashboards. Just a little trimming and you're set.
exactly!! Almost fits, just a little adjustment is needed.
