So Im looking at picking up a set of rims using the Refund Stimuli thing and Im wondering if they will fit
18x8"
+35 Offset
Going with a 35 tire, not sure on tire width yet?
Also im on AIR, rolled fenders already.
-thanks!
I would think they would fit. I'm running a 17x8 with a 35 offset. I'm have 45 tires of course, Falken RT-615's. they have huge shoulders, and it looks like they would only rub just a hair.
Desert Tuners
Hmm Im Just worried about when I lay it down, I ride low, Most likely will tuck the whole tire in the rear when riding, I just don't wanna gouge up my rim on the inner 1/4panel.
Friend has some 18x7.5 +35 with a 40 tire I may try just to testfit clearance.
SO lets see
Im going to test-fit one of Clints Re-verbs tonight, which is a 18x7.5 with a 40 tire on a +42 offset.
So When I test-fit that I can Measure out a 1/4" Wider on the face and back of the rim with a -2 offset right? I think....
Thats right...I think?
Im getting a +40, if necessary I can get a +3 or +5mm spacer, but i dont think ill need that.
Ill find out soon enough, been working late but another friend has some 18x8 +40 rims im gonna try.
^offset works like this.........
higher the number, the more it sits inward..
lower the number, the farther out it sits.
WiGM-Tuners member.
so then I guess it would be -3 or -5mm Spacers
So you gonna sell the stockers?
Possibly, If I can get enough to make em worth it, If Not ill keep em as spares.
My old rims are 16x7.5 with 35mm offset and 205/55s tires and they wont tuck.
+40 will put them 5mm toward the inside more, plus the 6.35mm (1/4") extra width on each side
If my Calculations are correct I will need 2 and 7/16" out from th hub of clearance (thats rim width 8" /2 = 4in-40mm offset)
Let me know if you do sell those and how much cuz I'm tired of rollin on steelies.
Well poo, somehow i got a little mixed up and thought the rims were +4-, but there +35, arg time to recalculate.
