i can buy some for cheap, and all i need 2 know is the bolt pattern. i cant really see the offset being that big of a deal. i know there 16's, and 5 bolt pattern. tires on them are 205/45/16 if that helps!
thanks
________________
WI-Jtuners member
eclipes? i believe they fit, same bolt pattern
Best quarter mile to date - 15.750 @ 85.82
"We ride together, we die together. Bad Boys for life"
Nimbus 9, some friends of my that rock! Click and experience them for yourself
yeah, off of a 98 gst eclipse!
________________
WI-Jtuners member
I dont believe they will fit. Our 5 lug pattern is 5x100 and the eclipse has a bolt pattern of 5x114.3.
I dont think they will fit. Our 5 lug pattern is 5x100 and the eclipse has a bolt pattern of 5x114.3.
I drive a 98 eclipse spyder and yes the bolt pattern fits.
P.S. 205/55/16
My 96 sunfire convertable project
then i think your crazy. even tirerack lists the Eclipse to have a 5x114.3 bolt pattern and i havent ever heard of tirerack lying
can anyone tell me 4 real?
________________
WI-Jtuners member
Stock eclipse rims wont fit on a cav, I tried it before.....
no diffrent bolt pattern...... they will not fit
not only is it the wrong bolt pattern but the bore size is too small so you would have to take them to a machine shop and bore them out
thanks for your help guys.
________________
WI-Jtuners member
