Will 1997 Grand Am Mags/tires clear the struts and whatnaught on a 93 cavalier base? I'm worried about the width of the wheel... they're 16's with low pro tires.
They should clear fine. bolt pattern is the same on a 97. If you can just stick 1 on and see if there is a clearence issue. Correct tire size on the 16 should be a 205-55-16. I wouldnt imagine there being a issue though.
2009 Ford Mustang V6
yes they will, same bolt pattern and bore size
right but he was asking about 97s which are the same as js
^ yea but it's not to make it clear though incase someone else comes in this thread and thinks all grand am wheels will fit. anything 99 and newer wont work on a J.
SO EVERYTHING!
