help with studs - Wheel and Tire Forum
help with studs
Thursday, September 21, 2006 12:59 AM
well my tire just fell off whiel iw as driving .. come to find out all my lugs are mistreiously stripped.. wll i go top bang them out and they wont come out the other end cuz there isnt enough clearance for them to get out.. not enough room.. this is a 99 sunfire 2.2 any ideas from experiemce on what i shoudl do.. i mean i cant take off teh whole hub cuz that bolts as big as ur fist and i dont have nothing that big and theres alan wrench spots too but once again i cannto ge to them cuz of lack of room someone hlpe me asap i need to get thsi running tonight so i can go to work or im screwed.. thanks alot guys
My Car Domain/My My Space/Likemyride.com/Showmeyour.com
Re: help with studs
Thursday, September 21, 2006 3:36 AM
Re: help with studs
Thursday, September 21, 2006 4:00 AM
just curious but do you have hub rings?
Re: help with studs
Thursday, September 21, 2006 12:25 PM
alias1429 (now with Ecotec) wrote:wheel stud replacement how-to
yo alias i luve u dude thankx u fukn saved my job lol
Re: help with studs
Thursday, September 21, 2006 7:17 PM
well couildnt take off the hub cuz i stripped the bolts but i bent them and took them out and replaced them with rear studs only problem is i didnt know there shorter oopss this shoudl hls up i hope
Re: help with studs
Friday, September 22, 2006 4:02 AM
Re: help with studs
Friday, September 22, 2006 4:11 AM
thats ok bagged, i heard you ask that already i guess he just didnt.
Re: help with studs
Friday, September 22, 2006 4:25 AM
yea im trying to find out if he does or doesnt cuz it could be the cause of the sheared studs
Re: help with studs
Friday, September 22, 2006 5:23 AM
im sure it didnt help, but i would probably assume incorret wheel torque. might even be a combonation of things gone bad, who knows.
Re: help with studs
Friday, September 22, 2006 6:06 AM
well ill be able to help the problem out more and let him know his chances of shearing off more studs if i can find out
Re: help with studs
Friday, September 22, 2006 7:50 AM
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]well ill be able to help the problem out more and let him know his chances of shearing off more studs if i can find out
to be honest wiht you i dont know and thats why i didnt answer at first cuz i wanst trying to look liek a dumass lol dont knwo the difference but i think the main prob was cuz i believe that rims was bent a little
Re: help with studs
Friday, September 22, 2006 8:24 AM
well i never out no wheel hubs on there..i dont knwo exactly what they r but i read in one fo the forums im suppose to have them with aftermarket rims
Re: help with studs
Friday, September 22, 2006 8:45 AM
its simple to find out if you have them. take one of your wheels off and look at the hub. there will be a little metal/plasic circle that is slide on the hub, between studs. if its not there then you dont have them (obviously). you want these because the hub rings take the weight off of the studs and center it on the hub. people that dont have them usually shear off studs alot because all the weight is center on the studs and not the hub. their cheap too, only like 20 bucks for a set. studs are also cheap too but do you feel like replacing them all the time?
Re: help with studs
Friday, September 22, 2006 10:02 AM
that would explain that.. where can i get them at liek autzome or what? cuz i know these wont last wiht ym recklas driving
Re: help with studs
Friday, September 22, 2006 10:26 AM
ebay has them and i think you can order them from some online tire places. youd have to look up the sizes on here though i dont remember off hand. i think our hub size that you need is 57.1mm
Re: help with studs
Saturday, September 23, 2006 5:27 AM
last time i looked at the plus size guide i think the centre bore of the cavs/fires is 57.1 mm. now you just need to know what the size of the centre bore on the rim is and your set.
my works starting to carry rings now. they are like $2.50 CDN, which is dirt cheap.
oh, and if anyone cares, apparently the VW Jettas/Golfs share our centre bore too.
Re: help with studs
Monday, September 25, 2006 3:42 PM
I got my car inspected, and tires rotated while I was there (feeling lazy, plus it was only $5 more since he had the rears off anyway)
A few days later Im doing my front brakes......one of the nuts got crossthreaded by dufus at the inspection, and it took a long sitting with an impact wrench and PB Blaster to get the nut off. This destroyed the stud, so I had to replace it. The Haynes manual was pretty useless, so I ended up taking the whole hub off, which meant buying a 32mm socket for the spindle nut. $8, no biggie. After I got the hub off, I could pound the old stud out with a BFH. The new one went in with a bit of a fight too, but the BFH proved to the best the best way to get the new one in too. Then, a little anti-sieze and it all went back together. Im convinced its the house I live in. It's cursed.
98 Sunfire 2.2L
Goat Skull in the rear. It's science not satan!
About 97% stock
Re: help with studs
Monday, September 25, 2006 8:02 PM
its 32mm huh? the huge one at the end of the hub right? thats what i couldnt get off lol i did it without taking off teh hub thing is i used shorter studs from a rear axel. big mistake cuz now they come loose so now i got ot get long ones grrr and i cant find the rings at all anywhere and autozone looked at me liek iw as stupid lol if anyone get5 real bored id luv a link thankz
Re: help with studs
Tuesday, September 26, 2006 5:26 AM
ur best bet would be to buy them online. just find out the center bore of our rims and your good. the hub size for our car is 57.1mm then all you need to know is the center bore from your wheel and you can probably buy them on ebay. just google the specs for your wheels, you should find them. if not call the manufacturer and ask them.
