Not sure if this is the right place to post this topic, but what is the right width and offset to tuck an 18 inch wheel?
I have a 2003 Cavy LS if that matters at all.
Thanks,
Danny
Under Construction
the wheel doesnt matter, the suspension is what does the tucking, if you want to tuck, you are going to have to modify your wheel wells or get some EXTREMELY low profile tires which will throw your speedo off. youd have to bang your fender well liners around, roll the fender lip. lots of work to tuck.
Vincent Morris wrote:the wheel doesnt matter, the suspension is what does the tucking, if you want to tuck, you are going to have to modify your wheel wells or get some EXTREMELY low profile tires which will throw your speedo off. youd have to bang your fender well liners around, roll the fender lip. lots of work to tuck.
not exactly. yes suspension has most to do w/ it because you have to have a suspension able to go that low first but then the wheel does matter. the width and offset play a big part that people over look.
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]
Exactly ,
