with they fit a 2000 sunfire i dont have a pic of what they look like sorry but i think they are 16's or 17's and are they the same bolt style thanks
no i dont think i believe they are 5x115? i know i wanted to use GTP wheels on my sunfire and i was told they wouldn't fit.
ok thanks any one know forsure if they will fit and if they wont what could be done to get them to fit?
IT can be done to get them to fit by doing a suspension swap or sumthing.. i dont know what exactly but i know CTS did it on his sunfire and is running on grand prix wheels and tires.. hopefully he'll see this or someone will that can explain it to you.. i just know it can be done and someone who has done it..
there 114.3 if i remember correctly. yes you can do the n-body swap for the rear but then that only converts the rear and not the front
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]there 114.3 if i remember correctly. yes you can do the n-body swap for the rear but then that only converts the rear and not the front
hmm this site says they are 16x6.5 and the sunfire is 16x6
^^ thats the rim size and width.. bolt pattern is what matter.. this is what allows all the lug studs to actually fit the holes in the rims.. if there differnt they dont fit without modification or force..
actually, you can swap the n-body front spindles as well... it's also in the suspension faq under the n/f/w-body brake swap...
they are a different bolt pattern though.
