Thought i would post an answer to a question i had and had to work with my local discout tire company to figure out.
18 x 7.5 konig unknowns with a 35mm off set will fit around a 13 inch front baer brake kit.
if i heard him right.
they should fit just fine considering the offest of the wheel is gonna bring them out away from the hub more than a stock offset wheel.
Topsub wrote:18 x 7.5 konig unknowns with a 35mm off set
If i'm not mistaken, 18x7.5 unknowns only come in a 45mm offset.
didnt i already answer this for you? go to baers site. download the template and print it out then you can put it behind your wheel and you'll know
baggebcav98 wrote:didnt i already answer this for you? go to baers site. download the template and print it out then you can put it behind your wheel and you'll know
wow.. didn't you read this is the
answer to the question They ordered me 18 x 7.5 with 35mm off set to allow enough room for the 13 inch baer brake
found a company in cal. that had them.
My girl has the Unknowns on her Eclipse, they look awsome. She gets alot of compliments on them. Be sure to post some pics.
2004 LS Cavy - everyday driver
http://temp.corvetteforum.net/c4/snakecharmer
www.myspace.com/streetdreamscarclub
Did you have them special ordered? Cause i have the unknown's and as i mentioned above, i thought the 18x7.5 only come in a 45mm offset. And i'm sure you did your homework, but i don't think the tires will tuck with a 35mm offset and bags anyway, doesn't that make the tire stick out away from the car? I could be wrong, but wouldn't you rub?
Topsub, off topic but how long from time ordered until you get your brake kit? Im considering this. Thx.
rocktizzle wrote:Did you have them special ordered? Cause i have the unknown's and as i mentioned above, i thought the 18x7.5 only come in a 45mm offset. And i'm sure you did your homework, but i don't think the tires will tuck with a 35mm offset and bags anyway, doesn't that make the tire stick out away from the car? I could be wrong, but wouldn't you rub?
*UPDATE* i got the rims in at discount and when we looked at them they were 5 x 114. The guy didn't know what he was talking about on the phone.
Now i have to find some other rims now. And i am not sure how it will tuck. but i will shave off everything i have to so theywill tuck. Plus i have a drift kit that hangs low anyway so it won't have to go but 4 inchs or so.
WHITECAVY wrote:Topsub, off topic but how long from time ordered until you get your brake kit? Im considering this. Thx.
I am not sure. I ordered them from jason and you know they are made to order so from what other people tell me be around 3 - 5 weeks.. Hopefully just 3.
^^^ Ahh ok, thanks man.. I heard 6-8 weeks, thats why I was asking..
soon as i get themin i let ya know.. Post order date and shipped date or received date.
Since received date can differn from person to person..
Topsub wrote:*UPDATE* i got the rims in at discount and when we looked at them they were 5 x 114.
The 18x7.5's come in a dual bolt pattern that will fit 5x100 and 5x114. Only the 8 width Unknown's come in a single pattern application.
^^ thtas what i thought.. I need to talk to the guy again and see whats going on.
yes, please, definitely do that.
