Hey everyone, I recently upgraded my wheels from 17 inch to 19 inch. I had hub rings on my previous setup (17's) and I was wondering, would the same hub rings be applicable to the new 19 inch setup? Or do i need certain hub rings made for a 19" rim?
Thanks for your time.
It will only work if the bore on the new 19" rims is the same size as your current 17" rims. If not, you need to order a set of hub rings that will fit correctly in the 19's.
tygriff
what is the bore?
how would i find that out?
just see if the ring fits snugly in the new rim if it does your good to go. You'd have to contact the rim manufacturers to find out wha the bore of their rims are.
ADR rims are 73.1mm I believe. Stock J hub is 57.1mm
-Chris
